Brake calipers and master cylinder
Hey guys
I found some brake calipers in good shape from a crushed Honda f4i and a brembo brake pump 16mm i think coming from a Ducati
Should I swap my old stock ones
Re: Brake calipers and master cylinder
A big yes. if they are the same type as the blade brakes they make a brilliant difference
- carmanbikes
I got F4i calipers and master cylinder its a good set up
- alanfjones1411
I got Ducati 916/996 usd forks,brembo calipers, 320mm full floating discs and Two Brothers m/c on mine.Brilliant stopping power,so yes do the swap
That combination of master cylinder and calipers should be a big step-up from the stock VTR parts. You will need to file some material away from either caliper or fork leg (or both) to fit these, and also space them off the fork leg by 3mm (I used 2 x 1.5mm washer superglued to the fork leg) to get the calipers to centre on the discs.
- bigtwinthing
go to a Yacht chandlery and get S/S ones that wont rust.Cadbury64 wrote:That combination of master cylinder and calipers should be a big step-up from the stock VTR parts. You will need to file some material away from either caliper or fork leg (or both) to fit these, and also space them off the fork leg by 3mm (I used 2 x 1.5mm washer superglued to the fork leg) to get the calipers to centre on the discs.
I didn't realise you had to space the calipers off the fork legs to center the disc's,Cadbury64 wrote:That combination of master cylinder and calipers should be a big step-up from the stock VTR parts. You will need to file some material away from either caliper or fork leg (or both) to fit these, and also space them off the fork leg by 3mm (I used 2 x 1.5mm washer superglued to the fork leg) to get the calipers to centre on the discs.
- bigtwinthing
The pistons ideally need to be in the middle to get equal movement. shimming them needs to be done on some set ups to make sure all is in alignment.sirch345 wrote:I didn't realise you had to space the calipers off the fork legs to center the disc's,Cadbury64 wrote:That combination of master cylinder and calipers should be a big step-up from the stock VTR parts. You will need to file some material away from either caliper or fork leg (or both) to fit these, and also space them off the fork leg by 3mm (I used 2 x 1.5mm washer superglued to the fork leg) to get the calipers to centre on the discs.
Didn't shim my f4i calipers and they look to be well aligned
D'oh!
Sorry everybody. I may have confused myself there regarding the spacers.
Spacers ARE needed when you use VTR forks on a VFR800 with 600F4i calipers. But they're NOT needed on VTR forks fitted to a VTR. Too many modified bikes in my garage (but don't tell my wife I said that...).
I was starting to get worried because I hadn't spaced mine either.
No problem, easy mistake to make. It was just that I've read about plenty on this forum who have carried out this front caliper mod to the Firestorm with no mention of spacing them off the fork legs that was all.Cadbury64 wrote:D'oh!
Sorry everybody. I may have confused myself there regarding the spacers.![]()
No we won't tell your wife, now where did I put that phone number again
I just had an idea. VFR bodywork on a VTR
stop that carlos lol..cybercarl wrote:I just had an idea. VFR bodywork on a VTR
