Regulator Rectifier Purchase
Well surprise surprise the the bike conked out on my first ride out last sunday , battery flattish limped home charged the battery and yep the voltage drops with the ignition on and bike running.
Advice welcome on wether to go OEM or is there an alternative thats man enough to do the job.
- alanfjones1411
Re: Regulator Rectifier Purchase
I got a mosfet r/r from roadstercycles.com in USA.I got the super kit minus the bracket and it was a really simple job took about 10 mins.Plug and play realy easy but not cheap,around £120:00 inc.tax & postage but worth it.
Mosfet FH020AA R/R > http://www.vtr1000.org/phpBB3/viewtopic ... ty#p351482
Plus you'll possibly need to get a new battery if the old one has been damaged when your R/R went down.
I got one off eBay that was finned and originally on a CB 125[THUMBS UP SIGN]. It's been ok so far
Sent from my HUAWEI GRA-L09 using Tapatalk
I've ordered a R/R from David Silver for change out of 80 quid, will post once fitted .
strekev wrote:I've ordered a R/R from David Silver for change out of 80 quid, will post once fitted .
http://www.ebay.co.uk/itm/HONDA-VTR-100 ... SwgmJX2AoO
R/R fitted holds 12.2 Volts across the Rev range and with all the lights on - good result
Tomorrow is Cam cover oil leak investigation day, its only an oil seal not a compression gasket so cover off check the rubber then sealant or new one.
12.2 volts is to low, needs to be above 13.5 volts with bike running and lights in, you may have a faulty stator.strekev wrote:R/R fitted holds 12.2 Volts across the Rev range and with all the lights on - good result
I had same problem on my CBR929, did read somewhere that both usually go hand in hand in given up the ghost together, so replaced both, a stator check an inspection will soon give the game away, stator replacing not bad, except draining the oil, so might as well do an oil and filter change whilst your at it.954luca wrote:12.2 volts is to low, needs to be above 13.5 volts with bike running and lights in, you may have a faulty stator.strekev wrote:R/R fitted holds 12.2 Volts across the Rev range and with all the lights on - good result
http://www.totalmotorcycle.com/maintenance/battery.htm
Yup double check battery and stator. Look for black burnt sooty windings on the stator rather than nice and clean and coppery coloured
When I took my stator off the blade I couldn't believe what I saw, where is had been in a crash and ripped some of the engine casing off it had also damaged ( quite badly ) the stator, to the point some of the conductors were actually coming apart, so instead of replacing it had sat on there for years being charged on a trickly charger.Wicky wrote:http://www.totalmotorcycle.com/maintenance/battery.htm
Anyway back on topic
To look at the stator its very visual to see when a stator is not good, its as wicky says should be nice coppery and not blackened.
When the go its not something that becomes apparent straight away not until about three conductors have gone as they take themselves out usually one at a time.
