Rear brake due for renewal
KermitLeFrog
Post by KermitLeFrog »
Well, the winter rebuild is under way. The rear pads are shot and the disk is also looking a little ridged. Any recommendation on new pads and disk? I'm thinking of using the OEM Honda pads and an EBC disk http://www.motorcycle-road-and-race.co. ... AhXE8P8HAQ
Recommendations?
Also, while I'm at it I need to order some taper roller bearing headstock bearings. Recomendations on those?
TIA
Ian
Re: Rear brake due for renewal
All Balls steering head bearings are meant to be good, plus these come with the seals as a kit:-
http://www.ebay.co.uk/itm/ALL-BALLS-STE ... SwPe1T~zLd
i put the all balls set into mine and they are a grand job :thumbup:
fabiostar wrote:i put the all balls set into mine and they are a grand job :thumbup:
Same here, it's a good kit
cheekykev
Post by cheekykev »
Yeah, agree with the above :thumbup: All Balls bearings, EBC or OEM disc and definitely OEM standard pads, people under estimate the Honda standard pads, I think they're excellent for road use :thumbup:
Like what you do
Do what you like
KermitLeFrog
Allballs ordered. Thanks for the tip.
Plus, found some Brembo rear pads (07HO36SP sintered) in my spares box. Just the jobbie.
KermitLeFrog wrote:Allballs ordered. Thanks for the tip.
INFO in this link on how to fit tapered steering head bearings, you can't use the torque figures in the workshop manuals as you would for standard ball bearing type bearings:-
http://www.vtr1000.org/phpBB3/viewtopic ... 62#p370942
countrymick
Post by countrymick »
ive got a new rear wavey disk if thats any good to you ian.
KermitLeFrog
countrymick wrote:ive got a new rear wavey disk if thats any good to you ian.
Thanks Mick, I should get my wheel back from Jonny today with a nice new BT016 on it. I'll properly check the rear disk and see what state it's in,
Ian
KermitLeFrog
Got the wheel back today with a shiny new tyre. Disk thickness is 4.8mm to 5.2mm standard. Seems a very large tolerance for a new part! Service limit is 4.0mm. Mine's 4.38mm. Good for another year I'd say.
