Battery Charging
kingbob
Battery Charging
Post by kingbob »
Hi,
A question for you all.
I have to store my bike outside, although it has various covers, so water tight.
I was going to fit a Solar trickle charger, as it doesn't get much use during the winter, just to keep the battery topped up.
Question is, do you have to disconnect the terminals from the bike when attaching the croc clips from the charger?
If you think you are right, or if you think you are wrong, you are right!
BigVeeGrin
Re: Battery Charging
Post by BigVeeGrin »
Your royal bobness - now I'm not one of the forum big brains for all things mechanical etc, but I have a Ctech charger conditioner that has leads for permanent battery terminal attachment, so when I need to plug in I just connect to the adapter - no need for crocs. Like in image below, so if it's fine for that then I guess you're good to just croc on
bazza696
Post by bazza696 »
I have a CTEK on both bikes and one is fitted with permanent plug with ring connectors on the battery the other has the permanent connector as shown below that indicates with a flashing LED if the battery requires charging, this is because the CBF has an immobiliser and flattens the battery after about 2.5 weeks.
Imageupload a picture
BigVeeGrin
bazza696 wrote:I have a CTEK on both bikes and one is fitted with permanent plug with ring connectors on the battery the other has the permanent connector as shown below that indicates with a flashing LED if the battery requires charging, this is because the CBF has an immobiliser and flattens the battery after about 2.5 weeks.
that's just so, errr, flashy!
bazza696
Post by bazza696 »
That's me
ChrisC
Post by ChrisC »
Sire, If I you, I would take the battery indoors and keep it charged there, prolonged cold weather doesn't do any favours to batteries.
cheers chrisc
bazza696
Post by bazza696 »
ChrisC wrote:Sire, If I you, I would take the battery indoors and keep it charged there, prolonged cold weather doesn't do any favours to batteries.
cheers chrisc
The summer house is insulated and heated so is never gets cold.
KermitLeFrog
Post by KermitLeFrog »
cheers chrisc
Summer House? If you were at all regal it would be called the Orangery. These royals have no class any more.
KermitLeFrog wrote:
cheers chrisc
Bazza has no class ! It's not a fekin Summer house it's a big shed... :Tongue:
bazza696
Post by bazza696 »
its a wooden shed with posh windows :lol:
bazza696 wrote:it's actually a log cabin
https://dunsterhouse.co.uk/premiumplus- ... 0m-x-d3-0m
oooooohhhhh get you... :lol:
Now where did I leave those woodworms...? :twisted:
