rear rotor tiny cracks
tastethefloor
Post by tastethefloor »
hi guys,
found some tiny cracks on the rear disk, like this:
Image[/URL]
pratically in every hole of the disk :thumbdown:
Do I need a new one?
VTR Phoenix
Re: rear rotor tiny cracks
Post by VTR Phoenix »
Are they cracks or scratches? Cracks then yes get a new one before it shatters, it has probably already scored the pads.
tastethefloor
VTR Phoenix wrote:Are they cracks or scratches? Cracks then yes get a new one before it shatters, it has probably already scored the pads.
How can I know if they are cracks or scrtches ?
VTR Phoenix
If they are cracks then they would be on the other side of the disc as well.
MK_WF
Post by MK_WF »
Pretty common in high performance applications like SuperMoto.
I have ridden quite a while with a much worse front disc.
It doesn't tear apart immediately, but if it does you'll likely crash. In Germany you'll loose road approval when the TÜV notices that damage.
I'd have a look for a new or used one and replace it these days without any hurry.
Bye
Martin
VTR Phoenix
Not sure if its just the picture but pinch the disc near the centre run your finger and thumb towards the outer edge of the disc, does it have ridges across the face of the disc? It looks like it could do but not sure, if it does then its time for a new disc also.
tastethefloor
MK_WF wrote:Pretty common in high performance applications like SuperMoto.
I'm going to replace it with one brembo
honda oem sucks
tastethefloor
VTR Phoenix wrote:Not sure if its just the picture but pinch the disc near the centre run your finger and thumb towards the outer edge of the disc, does it have ridges across the face of the disc? It looks like it could do but not sure, if it does then its time for a new disc also.
no ridges across the outer face
StuartWags
Post by StuartWags »
seen a few like that
vardypeeps
Post by vardypeeps »
Yeah, happened to mine yet the cracks were a little larger.
Disc had worn past ideal thickness and was getting too warm when used :(
