Honda rectifier converted to a Yamaha unit -How to
Posted: Wed Jan 25, 2017 8:45 pm
Hi, all. I thought that a how to do on the rectifier may be of a help. I fitted a new Yamaha one I got from eBay for about £16. The wiring does not correspond with the Yamaha one. Most seem to cut the wires and put new spades on, which is fine. I decided that I did not want that, so cut the connecting block down the centre long ways. I then sanded the 2 parts down to fit. The block and spacing of the connectors are different, so just swapping the connectors around in the block will not do, as the 2 rows are closer together.
