Page 1 of 1
Race shift
Posted: Tue Feb 28, 2017 10:23 pm
by bigr250
Quick question to the aficionado's on the board.
I've still not been close enough to a Firestorm to check, but from photo's I've seen it looks like a simple job of flipping over the shift arm on the end of the selector shaft to achieve 'race shift' of 1 up 5 down.
Is this the case or will it need a bit more modification? It looks like the clutch slave cyl' might be in the way, if indeed it is the clutch slave? :eh:
Thanks in advance.
Ross.
Re: Race shift
Posted: Tue Feb 28, 2017 10:33 pm
by tony.mon
Should work, you might need a slightly longer rod is all
However, chances are you'll be fitting rearsets anyway so it will be easier if that's the case.
Re: Race shift
Posted: Thu Mar 02, 2017 8:38 am
by fabiostar
Or what i done when i ran a race shift on my 7r, i put a stubby motox gear leaver on backwards ,
