Rear Brake Caliper Seals
carmanbikes
Post by carmanbikes »
Hi all, Does anyone know if the rear calliper seals only go in one way, I am sure I read somewhere the was a schamfer on the larger seal but I can't see it, Thanks in advance :thumbup:
cheekykev
Re: Rear Brake Caliper Seals
Post by cheekykev »
Has I remember correctly, yes they go in one way, just check how the old ones are fitted when you take them out, usually hydrolic seals have a v in them on the inside so the seal is forced out when pressure is applied, more pressure, more seal.
Like what you do
Do what you like
carmanbikes
Took the old ones out Kevin before looking at them properly, I can't see any difference no matter which way I look at the seal
They could be symmetrical, but usually the seal effectively springs back a little pulling the pad slightly back from the disc surface to avoid pad glazing.
The normal custom is that the printed information such as a seal size and code number is on the external face. Same with bearings.
If there are markings that might give it away.
carmanbikes
Thanks Tony I will check in the morning
