Personally I can remember way back when we would have killed for a 41mm set of forks, but again I am old =).
If the issue was with the fork tubes, you would think someone would have sourced a set of higher quality aftermarket tubes.
Though in reality the forks are actually pretty good. The issue is the triple clamp and even more so the steering stem.
So lets look at what I see as the main issue.
Here is a stock VTR stem:
and for comparison this is what you get with a SP or Blade triple:
Then pull out the measuring stick and you get this:
Stock -
SP-
and the final visual, the difference between the pins needed for a pit bull stand to lift each front end:
Which leads to my opinion that you can get very good results with the stock forks if you address the triple clamp issue.
