fork top nut or forks
Moderator: VTRDark
motojohn
Post by motojohn »
any body got a fork top nut or a bent fork with a good adjuster as i buggerd one of mine changing the oil as it refused to come out
If you think my attitude stinks ,you should smell my fingers !!
StormyRob
Re: fork top nut or forks
Post by StormyRob »
😐 saw the pic mate. Wish I could help. I do have a set of forks available but they are straight and a set which would be a tad expensive at 100 quid for just the nut 😂
I think I have one, will check after the workshop day tomorrow.
It's a bit dark in the stock shed now..
motojohn
Post by motojohn »
StormyRob wrote: Fri May 04, 2018 9:50 pm 😐 saw the pic mate. Wish I could help. I do have a set of forks available but they are straight and a set which would be a tad expensive at 100 quid for just the nut 😂
thanks Rob i may go there depending on how the strip down goes i was looking a a pair of cbr600 tops as they are the same but at £45 for just the tops your 100 does not look that bad
motojohn
Post by motojohn »
tony.mon wrote: Fri May 04, 2018 10:22 pm I think I have one, will check after the workshop day tomorrow.
Thanks Tony every bit helps
Yes, I have one. 7.50 posted?
Send me a pm with your details, and PayPal is fine.
If you haven't got 50 posts yet you won't be able to pm, let me know and we'll sort something.
motojohn
Post by motojohn »
Thanks for that Tony I have sent you a PM :beer:
motojohn
Post by motojohn »
money sent :beer:
Packed, will post Tuesday.
motojohn
Post by motojohn »
Tank you :D
