Thought I would give you all first shout before Fleabay.
As the title suggests I have for sale:
A red tank from a 1998. Includes the fuel sender. A few grazes and scratches but no dents. A little paint bubbling at the rear. The tank has had the fuel tap area re-brazed as it spung a leak there. £50 posted. £35 collected
I have a load of pipes and tubes: £16 posted. £10 collected
Carb rubbers: £15 posted. £10 collected.
Automatic cam-chain tensioners. Working fine when removed. One pink and one white dot: £20 posted. £15 collected
OR will post the lot for £70 or collected £55.
If you can collect them from Chepstow then they are much cheaper as postage prices are getting quite steep these days. You may also collect them from Barnwood in Gloucester on work days.
Tank, tubes, tensioners and carb rubbers for sale.
Moderator: VTRDark
You do not have the required permissions to view the files attached to this post.
Re: Tank, tubes, tensioners and carb rubbers for sale.
Second hand mccts.....russian roulette!
mdb wrote: ↑Mon Sep 24, 2018 3:25 pm Thought I would give you all first shout before Fleabay.
