Page 1 of 1
Rim tape removal
Posted: Mon Apr 08, 2019 2:43 am
by VTRsquid
Does anyone have any tips to removing rim tape with the tyre still on?
Dont want to douse it in solvents or too much heat.
Im guessing i could fashion a heat shield out of a bif of scrap ally or stainless that i can rotate around as i go with ths heat gun, but just wondering if there is an easy way?
Re: Rim tape removal
Posted: Mon Apr 08, 2019 4:46 am
by Kev L
If you've access to a hairdryer the heat is less and more controllable,, which would be better for lifting decals.
Good luck
Posted: Mon Apr 08, 2019 9:20 am
by cheekykev
As above, hair dryer then use GT85 to get rid of the remaining glue left behind.
Posted: Tue Apr 09, 2019 1:34 am
by VTRsquid
Cheers guys. So conventional methods it is then. Just have to be extra careful i guess. Not looking forward to it lol
Posted: Tue Apr 09, 2019 12:24 pm
by MacV2
VTRsquid wrote: ↑Tue Apr 09, 2019 1:34 am
It's not as scary as it seems, light heat get an edge up & once you can get a grip of it just pull it up as you continue to heat...
Top tips...use a plastic scrapper or a bit of wood whitteld to an edge...Do not use a metal scrapper !
Where some gloves, warm sticky plastic sticks to your fingers best let it stick to a glove than your fingers...
Lighter fluid, as you would use in a Zippo lighter is really good for removing the residue, whatever you use, lighte gas, WD or GT85...put it on a rag & rub the gunk off... Less chance of overspray on discs or tyres...
Personaly I would remove the wheel & do it flat on the ground...
Good luck, take your time & let us know how you get on...
Posted: Wed Apr 10, 2019 2:11 am
by VTRsquid
Cheers. Yeah had a quick go last night, couldnd find a plastic scraper so used a bit of carbon offcut, the rim tape is too cheap and u/v degraded to pull off clean, yet too sticky to scrape off nice, carbon was too stiff to conform and get purchase, was too tirsd aftef work, too full of warm beer, and too up to here with life in general to do more than 2 minutes lol.
Will haved a propper go at some stage soon. And yeah will defo take the wheels off and do it on a bench now ive had a taste.
Posted: Wed Apr 10, 2019 8:56 am
by Wicky
A wooden clothes peg used as a scraper won't damage the paint and instead of warm beer try IPA Isopropyl Alcohol.
Posted: Wed Apr 10, 2019 10:19 am
by VTRsquid
Ha! wooden clothsepeg, that is wombles genius. Isopropyl, ,,, is that the stuff that makes you go blind, mad, senile and sterile? I might just try putting beers in the fridge lol.
Posted: Wed Apr 10, 2019 1:40 pm
by Wicky
Special Part: Honda Racing Corp race choke modulator - when disassembled doubles as crud scraper...
Isopropyl Alcohol 99.9% Pure IPA 1 LITRE Lab Grade Party Pack
Posted: Fri Apr 12, 2019 5:10 pm
by tony.mon
Re your rim tape, you're not getting a sack back and crack are you? Gaffa tape works.
But I'd recommend a less masochistic method, I still have the tears in my eyes from two years ago in Devon.
And it wasn't even me it was being done to!
Posted: Mon Apr 22, 2019 3:19 pm
by Mourer
Was it that bad, Tony? sheesh! haha
