Shout-out for D.I.D. ZVM chains
jchesshyre
Post by jchesshyre »
I understand that the D.I.D. ZVM chain is actually the OEM fitment to the Firestorm, but I think many (myself included) use the less hefty VM one.*
However last time I decided to use one of the ZVM-X ones which are obviously more expensive, but I reckon it's worth the extra cash. It's now got 23,000 miles on it and shows no sign of tight spots or binding links and looks more or less new. I very rarely clean it, just apply 85W140 gear oil every 300 miles or so.
The price difference isn't that big so, depending on how many more miles I get out of it (I usually get 15,000-20,000 max out of a VX one), I reckon it's worth it.
*These are now ZVM-X and VX respectively for the X-ring versions.
Re: Shout-out for D.I.D. ZVM chains
storms can be rough on chains.. its a case of only getting what you spend with chains :thumbup:
Fit a cheap x ring, then spend the saving on a scottoiler.
jchesshyre
tony.mon wrote: Mon Jul 01, 2019 7:15 pm Fit a cheap x ring, then spend the saving on a scottoiler.
...or fit a scottoiler and a ZVM-X chain and never change the chain again?
jchesshyre wrote: Mon Jul 01, 2019 9:24 pm
Well that is what I have on my bike :D
fabiostar wrote: Sun Jun 30, 2019 10:53 pm its a case of only getting what you spend with chains :thumbup:
I agree with Rob on that,
jchesshyre
Confession time: I bought a Scottoiler two years ago and have yet to get round to fitting it :shh:
I don't mind manually lubing the chain, and like the fact that it means you check the condition frequently.
I know however that I'm a bit stupid not to have installed it yet, since it's undisputed that they massively extend chain life.
Is installation quite easy?
TaxiDriver
Post by TaxiDriver »
jchesshyre wrote: Tue Jul 02, 2019 2:07 pm Confession time: I bought a Scottoiler two years ago and have yet to get round to fitting it :shh:
Yes it is very easy to fit,sticking it under the seat is probably the easiest place for the resovoir although you can't get much verticality...……
Still works fine angled a few degree's though.
Minesabityellow
Post by Minesabityellow »
Or it rattles around, turns upside down and dumps its contents over your rear tyre.
TaxiDriver wrote: Tue Jul 02, 2019 5:20 pm
Cable tie it on the rh side, outboard between the subframe and the tail plastics.
Or buy the touring reservoir which fits behind the rear numberplate, althou I don't like the idea of adding weight that far from the c o g.
jchesshyre wrote: Tue Jul 02, 2019 2:07 pm Is installation quite easy?
I would say it was not straightforward, well not in my case, as I wanted to mount it to the seat sub-frame and route the oil feed pipe out of view as much as possible. I have fitted the S/Oiler in behind the seat fairing plastics on the left-hand side of the bike (side stand side).
**EDIT**
Just found a photo of when I was installing mine some years ago :wink:
TaxiDriver
Very difficult to mount to the subframe,as the bodywork usualy won't go back on.
Under the seat with a secure cable tie and it won't dump its contents.
Just slide it in place with the bodywork on and cable tie it in place.
But I used to be able to get the bodywork tail plastics off without having to remove mine.
TaxiDriver wrote: Wed Jul 10, 2019 5:20 pm Very difficult to mount to the subframe,as the bodywork usualy won't go back on.
Just to confirm. I have had no problems getting the bodywork off or on :lol: with it mounted in that position as in the photo 4 posts back.
It's only been there for 9yrs 8O
