Page 1 of 1
Cam/valve cover gaskets
Posted: Thu Oct 15, 2020 3:09 pm
by Wilky811
Can anyone suggest anywhere for me to buy a couple of valve cover gaskets? Cheers.
Re: Cam/valve cover gaskets
Posted: Thu Oct 15, 2020 3:18 pm
by Wicky
Posted: Thu Oct 15, 2020 3:44 pm
by Wilky811
Cheers. Great help
Posted: Thu Oct 15, 2020 8:00 pm
by tony.mon
Why would you possibly want some?
A slight smear of silicon and the old ones last for ever.
Posted: Fri Oct 16, 2020 3:39 pm
by misnblu
tony.mon wrote: โThu Oct 15, 2020 8:00 pm
Even after 22 years of service?
I would think the rubber would start to get brittle and go bad.
Hmmmm.....
Posted: Fri Oct 16, 2020 3:43 pm
by Wicky
is it leaking or are you planning to take the cam covers off?
As Tony said you only usually need a light smear of silicone gasket and care to keep the gasket in place when putting the covers back on.
Posted: Fri Oct 16, 2020 11:48 pm
by tony.mon
misnblu wrote: โFri Oct 16, 2020 3:39 pm
Hmmmm.....
It isn't rubber, of course, and I've not seen one fail. Ever.
To be honest they don't leak even if you don't use silicon, but I've always thought it pays to make sure.
Even the spare ones laying around in my stock shed are still ok, and they've been out in damp air for over five years at least, after ten plus years in an engine!
Whatever they're made of it's good stuff.
Posted: Fri Oct 16, 2020 11:57 pm
by misnblu
Well that's good to know as I'm in the process of rebuilding the bike and have the mcct's ready to go. I had planned on getting new valve cover gaskets as all the decades of me building cars has taught me that older cars valve cover gaskets get hard and break as you remove the cover.
Good to know and do appreciate the reply. I can save a few dollars now when I place my Honda parts order.
Posted: Mon Oct 19, 2020 11:44 pm
by Cadbury64
I've replaced the gaskets on my ST1100 chasing an oil leak. Turns out the old gasket (from 1990!) was fine, but the only things holding it down to the mating surface are the hold down bolts, and they have rubber washers that do compress over time. That resuls in less clamping force and not enough pressure on the gasket. My advice is to buy new washers for the hold down bolts, you could probably shim the old ones but they are cheap enough. Whatever you do, don't be tempted to just apply more torque to the bolts, by design they are bottomed out when tight, and more tension can only crack the cylinder head casting...
90543-MV9-670
Posted: Tue Oct 20, 2020 4:42 pm
by tony.mon
Good advice!
Make sure you fit the washers metal side up.
Posted: Wed Oct 28, 2020 2:19 pm
by Wilky811
I've got some MCCT's to fit to my '97 Storm. Thought it would need new gaskets. Not doing the job immediately but looking at what I'm going to need over the winter months.
