Exaust gaskets
DJWALKER
Exaust gaskets
Post by DJWALKER »
Hi need advice on this , does the gasket go into the pipe then get crumpled to fit guessing the bits get blown out of the exaust. Its the long peice im talking about not the seal to the head ? Any advice welcome as im not sure if im doing something wrong.
Re: Exaust gaskets
The Graphite gaskets fit into the pipe then you slide the other pipe inside, bit of lube helps, then clamp it up...
