carbs
sammy347
carbs
Post by sammy347 »
hi i just posted in the wrong section, vtr has been lyiny up about 5 months , i want to drain the carb bowls, does the fairings have to come off the get at them, cheers
Re: carbs
No need to remove the fairing. the drains are located on the right by the idle adjustment on the front carb and on the left on the rear carb.
If you are having trouble finding them, they are the flat bladed screw right above the drain nipples. :thumbup:
sammy347
Re: carbs
Post by sammy347 »
thanks for the reply mate, was dreading if i had to remove plastics
