Different keys?
Re: Different keys?
bingo808 wrote: Mon Jul 12, 2021 2:48 am
MacV2 wrote: Sun Jul 11, 2021 10:24 am
bingo808 wrote: Sun Jul 11, 2021 1:42 am
Good point. But I tend to think that my problem was half the reason why he was trying to sell it!
I assumed (which makes an ASS of U and ME) that the locks would match.
Oh well. You live, you learn.
Another it's a bit late post...but I would have wanted to look in the tank before buying to check for rust & how much fule was in it if I was riding it home...
Still you live & learn...You'll never do that again...I hope... 8O
All good. The bike was towed home as no registration. Bit of impulse buy I'll admit.
I paid AUD$1700 for it (around 900 pounds) so it's nothing spectacular.
Ah that makes sense,
bingo808
Re: Different keys?
Post by bingo808 »
Well, I managed to get the old fuel tank lid lock out.
I drilled a pilot hole all the way through - about 7-8mm diameter.
Then I tried a 14mm bit from a drill set that I bought of ebay. It drilled a bit, but the tip didn't last. You get what you pay for!
So yesterday I bought a 15mm bit (from a trades store) and used an electric drill to drill into the lock. The lock popped up before the bit broke through the bottom.
Now I have a new lock to fit, plus a new ignition switch/barrel to match the fuel lock. The original Honda switch on my bike works for now.
I guess if I replace both fuel tank lock and the ignition switch I'd have one key for both. I'll see how I go.
Someone put it together, so I should be able to pull it apart.
Re: Different keys?
Well done...
Your next task is to get the ignition switch off...
UK bikes have secutity bolts fitted, when fitted @ torque setting the heads snap off...
So get that drill back out...
If your lucky they will be normal bolts... If not take the yoke off for better access...
Re: Different keys?
Well done, at least you can now get fuel in the tank :thumbup:
bingo808
Re: Different keys?
Post by bingo808 »
ignore
