Anti
Anti
Just wanted to ask if anyone here ever used milk of magnesia on exhaust manifold studs. I'm putting on a split flange and going to use ss bolts. I was just reading about mm on another forum seems it's even used in jet fighters as an anti seize. Cheers
Re: Anti
Hahahaha MM No...
50/50 ATF* & Acetone. Works wonders...
Give them a good soak over a week with a fresh dob daily. Use a decent stud extractor & give it a wee nip up to break the corrosion bond...
*Automatic Transmission Fluid... ATF
Re: Anti
dont know if i should, but i put copper grease on a lot of my fixings
