Penske remote reservoir triple adjustable shock. Adjustable for high and low speed compression damping, rebound damping, preload as well as length.
Serviced three years ago so it has good seals and everything works as it should. Fitted with a 90Kg spring so should work for someone up to 85Kg. The shock length has been adjusted to 2mm longer (347mm) than the stock fork length.
£500 ono, + P&P
Penske 8987 'race' shock
Moderator: VTRDark
- freeridenick
You do not have the required permissions to view the files attached to this post.
Re: Penske 8987 'race' shock
Hi Nick, to keep in with our Forum rules can you please add a price? and state if p&p is extra or included?
I'm guessing this slipped your mind
- freeridenick
