(19 March 2005, Michigan) "Unusual" and "complicated" is how the Missaukee County sheriff described the mysterious death of 19-year-old Christopher, who called 911 at 1:22am and calmly informed the police dispatcher that his neighbour had stabbed him. Suddenly he began screaming and begging for help. A woman was heard shouting in the background, "Why did you do this?" Deputies arrived quickly, only to find that Christopher had bled to death from stab wounds to his chest.
After an evening spent imbibing large quantities of alcohol, Christopher noticed a shortage in his liquor supply that could not be attributed to his own depredations. He concluded that his neighbour had stolen a bottle of booze! He menaced said neighbour with a knife, to no avail, whereupon he retired to his own apartment to brood about revenge.
Finally he figured out the perfect way to get back at that conniving bottle-thief: he would stab himself and blame the neighbour!
A witness saw Christopher enter the bathroom while he called police. When he emerged from the bathroom, he looked perfectly fine, but a moment later he began screaming as gouts of blood spewed from his chest. He ran to the door of the apartment, and collapsed.
The evidence pointed to self-inflicted wounds. Deputies found the knife that killed him in the kitchen, and an autopsy concluded that he had stabbed himself in the chest twice. The first wound may not have looked dangerous enough to him, so he took the knife and tried again, this time plunging it into his left ventricle. This wound was plenty dangerous: he had only two minutes to live.
Christopher died in vain. His deathbed accusation fell on deaf ears, as a witness stated that the neighbour was not in the apartment, and the neighbour offered to take a lie-detector test to demonstrate his innocence. All Christopher got for revenge was an accidental death sentence.
(13 January 2005, Bizkupija, Croatia) On a Thursday afternoon around 4:30, 55-year-old Marko went into his semi-detached workshop to make himself a tool for chimney cleaning. The chimney was too high for a simple broom to work, but if he could attach a brush to a chain and then weigh it down with something, that would do the trick. But what could he use as a weight?
He happened to have the perfect object: it was heavy, yet compact, and best of all it was made of metal, so he could weld it to the chain. He must have somehow overlooked the fact that it was also a hand grenade and was filled with explosive material.
Marko turned on his electrical welding apparatus and began to create an arc between the chain and the grenade. As the metal heated up, the grenade exploded. The force of the explosion killed poor Marko instantly, blasting shrapnel through the walls of the shed and shattering the windshield of a Mercedes parked outside. Marko's chimney was untouched, however.
Darwin Awards 2005
Darwin Awards 2005
