Mine seems to go through stages. Won't use any for ages & then she's empty within a coupla hundred k. It's like it forgets to use any & then realises & makes up for it. Doesn't seem to be relative to any particular riding style either. I've just got into the habit of checking fairly often.
I only ever lost about an eggcup full between services.
Normally towards the last few hundred before it got changed. I just put it down to the oil getting old and thin
Pete.L wrote:I only ever lost about an eggcup full between services.
I wish I was like Oil I'm getting older but definately not thinner
Mine tends to use about 100 ml or so every 5000 kms (don't know what that is in miles) but I have been told it is fine and this is normal in hard running motors. I use mine at a track from time to time and mine has been jetted and filtered etc....
