Me Z750 on the dyno (vid)
firestorm996
Post by firestorm996 »
Had my Z750 on the dyno the other week at the VTR dyno day. Only 'power' mod is a Blueflame twin-exit oval pipe with bottom baffle drilled through rather than removed, top baffle still in. Result was 103rwhp. We had to do a through-the-gears run to see if it was running lean/rich as the lambda probe wouldn't fit down the blueflame properly. It's running slightly rich (no power commander) so removing a baffle would gain a bit more power but would be too loud for the road (already tried it). Curiously, the fuelling in 4th is almost spot-on and it nudges 109bhp, 5th/6th are 103bhp or thereabouts though. I thought 'optimistic dyno' but it was giving 103-108bhp for all the VTRs which is spot-on and consistent with the same bikes on previous dyno events we've had.
It was weird to discover that there's about 3k of revs I've never used, the limiter doesn't actually kick in until the tacho shows 14k (alllll the way round). Ah well! I've always changed up at 11.5k or near as dammit.
http://www.supermoto.ndo.co.uk/storageb ... t-run1.mpg
http://www.supermoto.ndo.co.uk/storageb ... t-run2.mpg
http://www.supermoto.ndo.co.uk/storageb ... t-run3.mpg
http://www.supermoto.ndo.co.uk/storageb ... t-run4.mpg
http://www.supermoto.ndo.co.uk/storageb ... ugears.mpg
Firestorm996
'98 VTR in black - road whore - track bitch
8O Howling Hornets Nests Batman 8O
:twisted: Love it :twisted:
Rincewind
Post by Rincewind »
hmmm, think i'llget the cct's done before i try one of those!!!
awsome tho'!! :wink:
Never argue with an idiot, they will drag you down to their level and beat you with experience.
firestorm996
Cheers guys
A VTR on the dyno sounds better, but jeeeezus does it howl!! Bloomin loud too, tryin to video it with one hand to cover both me ears was tricky :)
Firestorm996
Pretty impressive stuff :!: :D
