anyone try a 190/55 rear tire?
The new ZX-10 comes equipped with a 190/55 rear tire. Based on the fact that many have tried a 190/50 rear with mixed results (the negatives being traced back to the lower profile), I was wondering if anyone has tried this new higher profile rear, and if so what were the results?
cheers
Mikstr
cheers
Mikstr
- Stormin Ben
190 tyre is designed to fit on a 6" rim
If you squeeze it on a smaller rim the profile goes all to rock
I can't see it putting any more rubber on the road than a standard tyre
However, it would look good so for some thats justification enough
But its not a very good one!
- Skatrekker
Expensive if it doesn't improve things, why bother, all it will do at best is give you bigger chicken strips for people to mock. The fact that you are forcing the tyre onto a relatively narrow rim means that the profile will be different to that it was designed to have. Unless you have several years experience in motorcyle tyre research and development I'd leave things well alone or accept that you might have found a way to make a bike less stable.
A track day or a riding course will make probably make you faster round corners.
- Squiffythewombat
- Contact:
alrightee then! next topic, lol
thanks guys
By the way, I was not trying to infer that it would make me a quicker rider; I have been riding long enough (28 years) to know that the limiting factor with most modern bikes is the rider and not the machinery. I was merely throwing the idea out for discussion, and discuss you did!
cheers
Mikstr
thanks guys
cheers
Mikstr
Exacatly! INMO...same as steering dampers...[/quote]
Hows that then? Sorry to hijack thread but im not 100% clued up on steering dampers mine has one but my chicken strips are less than 5mm how do they stop you leaning in then
VTR1000 Firestorm P(97) - Double bubble screen, Braided Hoses, Gold anodised Scorpion Race Cans, Sprint Steering Damper, Black Pyramid Hugger, Gold Chain (Bling), Scottoiler. Lots more to come.......need more thump
- Contact:
- Stormin Ben
They don't stop you leaning (although they can affect the speed you can tip in) but I think the point the Squiffy Wombat was trying to make was that a steering damper on the Storm is totally not required.Tinter wrote:Hows that then? Sorry to hijack thread but im not 100% clued up on steering dampers mine has one but my chicken strips are less than 5mm how do they stop you leaning in thenExacatly! INMO...same as steering dampers...
If you find you need one then its just gonna mask a problem, not solve it. You're better off addressing the cause (eg get the forks/ shock/ suspension linkages/ tyres sorted instead
Not sure i agree, the storm is not notorious for shaking its head al la 2004 zx10r/ 1995 blade, but an bike can have a tank slapper momen given the righ curcumstances, a steering damper does not affect the way a bike is riden of turns. You only really ever notice it at very low speeds, and really who cares about the steering being a bit heavy in a car park at 10mph!!!Stormin Ben wrote:They don't stop you leaning (although they can affect the speed you can tip in) but I think the point the Squiffy Wombat was trying to make was that a steering damper on the Storm is totally not required.Tinter wrote:Hows that then? Sorry to hijack thread but im not 100% clued up on steering dampers mine has one but my chicken strips are less than 5mm how do they stop you leaning in thenExacatly! INMO...same as steering dampers...
Just my 2p worth,
Slim, Firestorm owner with steering damper fitted.
It's here.........
- Contact:
