Cleaning
Cleaning how? Just cosmetically, or super seriously to remove blemishes?
First option, tianium wont rust, so normal soapy water should do. You can even remove tough grime / chain lube etc with something like Autoglym degreaser spray.
Second option, most jewellers use acids (mainly citric acid as its relatively easy to get hold of and use) to bring up a high level finish. Wouldn't advise this unless you knew what you were doing.
just so it don't look dirty, soapy water it is then, I just didnt want to screw up the surfaceKitch wrote:Cleaning how? Just cosmetically, or super seriously to remove blemishes?
Max
- Squiffythewombat
- Contact:
