URGENT HELP NEEDED NOW!!!!!!
david greenwood
Post by david greenwood »
Does anyone know if a 92 fireblade front end inc yokes will fit straight on my R Reg VTR
Also the wheels?? off a blade as well
Need to know like NOW please
Dave
Squiffythewombat
Post by Squiffythewombat »
Dave if you need to find out NOW...use the search fuction as this has been covered many times before as kaz said.
From memory to fit blade forks you need to raise or lower (cant remmber which) the yokes by means of a spacer. I know they wont bolt straight on but its not hard!
Early blades have that nasty 16" front so im not sure if they will fit but CBR wheels fit a treat, several people here have done that!
Obviously tho if your using a blade front end the blade wheel *should* fit straight on.
Im a newbie to most of this, so if im wrong its not my fault! :D
Squiffy_The_Wombat
david greenwood
forks and stuff
Thanks personally I think my Boy has lost the plot, if you must have a V twin he should go SP2 or Ducatti. Me as an old codger I will stick with trust in line 4 ZZR1100, its a tiger with a growllllll like from the depths of hell, and over 50mpg no contest, hahahaha
thanks though for input I will pass it on to him.
Dave
