VTR Speedo accuracy
chrisk992003
VTR Speedo accuracy
Post by chrisk992003 »
I'm sure my speedo is under reading - travelling down the m4 everyone seems to be travelling at 90 and occasionally 100. I do the same journey in my car and things are a lot slower. I reckon I'm reading about +10mph
Anyone else have this problem and can you get it adjusted ?
Fireman on a Storm
Post by Fireman on a Storm »
Your speedo may read under if you have a 15 tooth front sprocket instead of a 16 standard one. But only by a couple of mph.
Have you got the correct size rear tyre?
You can get a different reading between a brand new tyre and a very worn out one.
To check your speedo against the car or another bike travel a set distance in both and check distance traveledon the trip meter.
If your speedo is under reading you will have covered a greater distance than one reading corectly. The only 100% accurate speedos are in traffic police cars.
A freind has a 15t on his TLs and over 100 miles his bike reads 103 miles compared to my standard 16t bike
delmeekc
Post by delmeekc »
I use a GPS to set all my speedo's up, see if you can borrow one from somebody, will be accurate to 0.01 mph.
Del.
Fireman on a Storm
Not up with this high tech stuff how do you do it with GPS
chrisk992003
Del - I suppose that means you can adjust the speedo - I'm guessing a screw on the back ?
andy c
Post by andy c »
I check the accuracy on all new bikes and cars by following a truck on a fastish road all large trucks have a speed limiter fitted accurate to 2% much more accurate than a speedo 10% and should be set to 56 mph max most vehicles ive driven / riden read about 60mph when following its not spot on but it gives you a good idea
t00lkit
Speed
Post by t00lkit »
May sound obviuos, but here goes..
How about getting a mate to drive down a section of Motorway/daul carriageway and agree a speed to drive/ride at. Say 70mph.
You can then see what you are reading and compare?
t00lkit
Stormin Ben
Post by Stormin Ben »
I normally ride down the motorway at a constant speed and time how long it takes to do 1 mile according to those little marker posts at the side.
Then with the aid of my trusty Mr Men calculator and using the equation Speed = Distance / Time I can work out my actual speed versus my indicated speed
Then I normally have a lie down coz my brain hurts!!
Ben
Stormtrooper
Post by Stormtrooper »
well how about looking for a plod with a speed gun & nail it past him whilst
looking at the speedo then when & or if he catches you you will know how correct the speedo is... of course this method can prove costly :wink:
im usually (A) to busy looking where im going or (B) hanging on for my life to bother to much if the speedo is plus or minus 10%
just ride it 8)
philsmith
Post by philsmith »
Stormtrooper wrote: just ride it 8)
I agree... Just get on & give it some... 8O
:lol: :lol: :lol:
Have fun & Ride Safe.
Phil.
