does any one have anything by hannspree? i know there wsbk team is ace and i expect Johnny Rea to win the Title this year but are there tv's any good?
im looking for a 16:9 aspect ratio 1080p fair priced tv for the bedroom preferbly larger than 22 inch to be used for blueray, dvd, tv and conecting laptop via hd too and can be mounted to a wall.
found this offering from HANNspree its a 25" (odd size but what the hell) price is very reasonable from
223 quid here.... http://www.misco.co.uk/applications/Sea ... CatId=3475
230 quid here ..... http://www.morecomputers.com/extra.asp?pn=st251mab
255 quid at amazon http://www.amazon.co.uk/Hannspree-25-in ... =de_a_smtd
Specifications
Product Description Hannspree ST251 25 Inch LCD TV Full HD
Diagonal Size 25"
Device Type Widescreen LCD HDTV
Max Resolution 1920 x 1080
Aspect Ratio 16:9
Contrast Ratios Typical : 1000:1
Dynamic : 10,000:1
Brightness 300 cd/m2
Response Time 2ms (GtG), 5 ms (Typ.)
Viewing Angle 170°/160°(H / V)
Input Video Format 1080p, 1080i, 720p, 576i, 576p, 480i, 480p
Viewing Aspect Ratio Full / Panorama / Zoom / Subtitle / Auto / Normal
TV System DVB-T (with Common Interface) / PAL / SECAM
Colour System NTSC / PAL / SECAM
Video Features 3D Comb Filter, 3D De-Interlacer, Noise Reduction, 3:2/2:2 Pull Down
Video Connections HDMI 1.3 x 2; YPbPr (Component) x 1; Full Scart x 1
VGA (PC) x 1; Composite x 1
Speakers 10 Watt x 2 Channel
Audio System Nicam/A2, MPEGI & II
Audio Interface HDMI / PC Line-in input x 1; AV/SV/Component R/L Audio Input x 1; Earphone Output x 1
Power Consumption ON: 65W (Typical)
Stand-By: < 1W (Typical)
Net Dimensions (W x H x D) 605 (W) x 442 (H) x 155 (D) mm with Base
605 (W) x 414 (H) x 74 (D) mm without Base
Weight Net Weight: 7,62Kg
Gross Weight: 9,25Kg
VESA Wall Mounting 100 x 200 mm, 6 Screws, M4
Package Contents User Manual, Quick Start Guide, Remote Control + Batteries, Cleaning Cloth
other options are the LG 32inch 1080p LCD TV but thats around the £370 quid mark and id ryher not spend that if this is any good, unless you guys know of any good deals out there that aint sh1t makes like that techninca crap teasco flog!
