Cure for clutch rattle anyone??
marlbororman
Re: Cure for clutch rattle anyone??
Post by marlbororman »
tony.mon wrote:
dookie wrote:Bets cure is ignore it :Beer Popcorn:
Straight-through cans do the trick
Maybe thats why i cant hear mine :lol:
Rider on a Storm
Post by Rider on a Storm »
:thumbup: but u cant keep it in the red in town thats when i hear it & at lights, getting carbs balanced n oil change, goin to bleed clutch as suggested in older post, all these may quiten it a bit
Tray
Rider on a Storm wrote::thumbup: but u cant keep it in the red in town
No, but my hearing's shot from the faster bits, so it doesn't trouble me at all.
Mine rattles more than a sextuplets' christening party.
marlbororman
I have clutch rattle :lol: :lol: :lol: Listened carefully and i definately have it, I dont feel left out in the cold anymore :thumbup: :lol: :lol: :lol:
Rider on a Storm
:lol: will leave well enough alone so :thumbup:
Tray
There's only three reasons to pull the clutch on a Storm:
1- it slips under power (but try using semi-synth instead of fully-synth oil)
2- the clutch basket fingers have notches worn in them, making clutch operation jerky at the lever- won't feed out smoothly at all times, or
3- clutch locks up under full-power hard getaways, with a horrible graunching sound, and almost certainly a huge unintentional wheelie.
If it's 3, then good luck with a cure, some bikes do it and some don't.
But swapping all the clutch components, bearings, plates, etc, won't cure it, in my experience. I only got mine fixed when I changed to another engine, which didn't do it at all.
But I personally suspect play in the big bearing behind the clutch, which is an engine-out and crankcases split job.
Reason being that when I first changed my engine it was because that bearing completely self-destructed, but to be fair I thrash it on the drag strip sometimes so not really normal usage.
Pretty much all Honda clutches rattle, live with it and be glad you haven't got a dry-clutch Ducati!
Rider on a Storm
Almost did the ducati thing but then the hangover kicked in :shh: and a little voice said "go to the land of the rising sun my child" :lol:
Tray
marlbororman wrote:
Pete.L wrote:No it's not bad, just unusual...Now go and touch something wooden :wink:
How many miles have you got on the clock?
25000 miles or there abouts, maybe a few thou off dunno without going and looking lol
Kinnel 8O
Well impressed...or yo have a hearing dificiency :lol: :lol:
No, just kidding. 25k shouldn't be a problem for any modern engine.
IgorVigor
Post by IgorVigor »
I think mine rattles :S
I had a 1997 CB500 before, which are notorious for clutch rattle so I dont really worry :P
I can only think of one Honda that I have heard that didnt have a clutch rattle...
it was an old Honda C70...mind you, everything else rattled on it...
benny hedges
Post by benny hedges »
Rider on a Storm wrote: in town thats when i hear it & at lights
mines same, doesnt really go when i pull the clutch in, but does as soon as i put it under load.
pulls fine, no slip, no vibes.
dont worry about it.
a jamaican looking taxi driver pulled up next to me today and said 'man you know what that rattle is? thats your camchain is going to go.....
i said crouton off, never?? do they have these in pakistan then??? :lol:
LotusSevenMan
Post by LotusSevenMan »
Well as I have a full open and ventilated cover on my '916' then I don't even think about that as a Honda problem! :lol:
V-Twin Racer
Post by V-Twin Racer »
oh no... how LOUD is the rattle... lol... i got rid of my XJR because the very loud rattle did my head in... again a split the engine open job... & a ZX9R did the same... but on that engine... you just need to pull the clutch & replace the Alternator chain behind it... very easy !! :cool2
does it go quieter with the headlights switched on !? :?
darrenbiker
Post by darrenbiker »
Mine fell off the stand and landed on LH side bending clutch lever has rattled since . Will fix at some point
tony.mon wrote:There's only three reasons to pull the clutch on a Storm:
I had very bad case of 3) [even mild throttle openings would result in "grunch - lock - wheelie] and sorted it with a full clutch swap including basket and actuator top hat, the only difference I could see was the actuator...see this link.
http://www.haymouth.co.uk/phpBB3/viewto ... 95#p172291
vtryorks
Post by vtryorks »
So is it correct to say that if an engine rattle disappears when the clutch is pulled, that it is NOT a CCT failure?
The answer to that might assist me greatly!!
