Adjusting APE CCTs
Re: Adjusting APE CCTs
I had the same, but from cold.
The sound only lasts for about a second as it starts.
I backed the tensioner of half a turn and that cured it.
Try backing yours of just 1/4 turn as it only does it when hot.
Jim67
Post by Jim67 »
Cheers Pete, I have backed them off a tad now, I will see what happens next time its at temperature.
Cheers again,
Jim.
RACIST!!! not me....I'll race any fooker!!!!
LotusSevenMan
Post by LotusSevenMan »
Jim67
Yep, that sounds slightly too tight to me. Back of a fraction and see if it gets better. That blowing/whirring noise is a classic 'too tight' sound.
Jim67
Post by Jim67 »
Cheers for the help guys, I had a play the other day and reset them with the engine running and at temp but I reckon they are a tad too loose now so I am going to wind em in a tad today, I get there in the end........its not easy to have peace of mind !!!!!!!!
Jim.
LotusSevenMan
Jim67.
I wouldn't go in a tad. A gnats nodger or a smidgen at most!!! :lol:
LSM
mwross1964
Post by mwross1964 »
Ok , got the manuals fitted.But once up to temp and I pull over with the bike still running I heard a slight tap... tap.... tap, and then it stopped, then I drove home (20mins) leaving the bike running again, and I could hear the chains like,rubbing against the bolt , is that normal or are they too tight or to loose? The mechanic fitted them 2 days ago before putting in the replacement engine,should I do it or get him to do it if it needs it.
anything with wheels or tits is gonna cost ya money.
but who needs money
mwross1964
anyone?
but who needs money
Phil-VTwin
Post by Phil-VTwin »
Sounds like they need slightly more tension, if he gave you any guarantee then get him to do it FOC :)
Ride Safe
Phil
bikerpiker
Post by bikerpiker »
If you paid him to do the job, and you think you hear a noise which doesn't sound right ,after him fitting the new cct's,by all means get him to double check.....better safe than sorry :!:
Stevie
bikerpiker wrote:If you paid him to do the job, and you think you hear a noise which doesn't sound right ,after him fitting the new cct's,by all means get him to double check.....better safe than sorry :!:
+1
gaz
Post by gaz »
Just fitted manuals ccts on mine. Sounds about the same when cold, maybe a little more whirring than ticking. When I got it to temperature the 2500-3000 flapping noise from the front tensioner came back. Do you thing I should tighten it a little or I got nothing to worry about now?
benny hedges
Post by benny hedges »
if they are whirring they are probably too tight bud.
you'd be ebtter slipping the cam covers off to check the tension - it should be quite slack... more than you'd expect!
i set mine so i can move the chain about 10mm - 5mm up, 5mm down.
check it by removing the cam chain cover between the gears - stuff some kitchen roll down the hole tho just in case you lose the middle bolt, and use threadlock on them when you put them back in!
also - posted this a million times.... put threadlocking compound on the long tensioner bolt.
don't rely on the locknut to keep it in place - twice mine came undone, and the same has happened to other owners.
threadlock it and it wont come loose - and get the locknut as tight as possible.
the oring is there as an oil seal so dont just nip the nut up on the oring!
TUG
Post by TUG »
Mine is fine till gets to temp, it ticks louder but my cam chain tensioners keep backing off quite alot.
Gunna fit these MCCT's but i thought you only have to hand tighten them up then lock it down. my cam covers are gunna be coming off anyway,
so will check anyway.
TUG
Post by TUG »
I've fitted my MCCT's off thepont, and ticking at 3000rpm-4000rpm is still there, i've backed them off and tightened them up, its a tiny but quieter when tight, but i just cant get to the bottom of it.
Also my VTR codename Thumper has eaten its front carb O-ring... yea i know.
