Here's to hoping it turns out well this time.........
On the "to do" list:
- I am waiting on some parts (Pro-Bolt bits) at the moment, mostly Ti, will install those in due time.
- replace calipers with F4i (strictly for aesthetics, as they are mechanically identical to what I am running now), will clean the "new" ones and put new seals in while I am at it
- replace current MCs with Ducati OEM Brembos from a Monster 1100 (with Pazzo levers); the brake MC, which is a 19x16, should give me more leverage (albeit with longer travel) than the Nissin 19x18 I am running now
- picked up a rear hugger than needs to be painted and mounted; I've drilled a few holes to secure it on the swingarm brace but will be trying some automotive grade double-sided tape to hold it in place at the front (too confined an area to get in there with the drill, so am working on a plan B, hopefully it will work out, with the three small screws in there for peace of mind)
- new front tire (MIchelin Power Pure; to match new rear, front was on BO when I had the rear changed over); will be getting the tire valve changed to a fancy little angled aluminum item
- various stickers to install
- Accossato quick-release fuel cap (in red, should be here any day now)
- exhaust re-packing (picked up some Akra re-packing kits; will wait to fire it up again before deciding if I will do it now or put it off for a while)
- bought a spare rear swingarm pivot bolt (stock is hollow) and filled it with epoxy (to make it more rigid), will be putting it in place of the existing bit; trying to make everything more rigid to better handle the modded engine's higher output (less flexing in the cases and swingarm pivot area)
- I have a set of K&T rearsets that I am debating on installing or not; I ride strictly on the street so may very well choose to part with them at some point, time will tell (my current shifter, machined from CNC, pivots in needle bearings so there is nothing to be gained from replacing the shifter side in terms of taking slop out of the system)
That's it for now. Will post pics when it's all done
