UPDATE:
I was made redundant recently, and so last working day was yesterday.
Good news is that i have found another job (actually typed another position first, but I can't give away opportunities like that
) and it doesn't start until Monday 26th March.
I'll use the bike for the commute for a while, so it needs to be on the road and ready by then.
But that gives me a week to do a full engine strip-down and rebuild.
Last winter's rebuild was using a donor engine that had a lot of wear on the front cylinder; the piston wasn't a good fit but I went ahead anyway as I wanted it back on the road.
But since then i have acquired a couple of spare engines, one of which is low mileage but has a gearbox problem; jumps out of second.
So I'm going to strip the engine out of mine, and rebuild it using the high comp pistons (possibly swapping them round, front to rear, to equalise wear) but using the donor crankcases, crank, and rods.
I'll move across the gearbox from mine, as it's known good.
Clutch? I'll use the Kevlar plates I have, and make up a best set form the metal ones, and use the least-worn parts form all, based on AMcQ's experience I may fit a new top hat sleeve and bearing while I'm there.
I'll leave the hybrid hydraulic/cable conversion on for now.
Obviously any bearings, seals and other parts get renewed along the way, although if the mains and big ends on the donor engine look OK I'll leave well enough alone.
I am currently running heads that I've gasflowed myself, and modified cams, which I'm tempted to put back in for now, but have a set of spare heads fitted with four exhaust cams- minor differences, but apparently beneficial.
I plan to change the valve timing slightly, 5 degrees advance on the inlet and a little more on the exhaust as I want t bit more overlap. It'll further ruin fuel consumption but should increase power a little, but before I get to that stage I'll revisit all of my notes about cam timings for Mori, Kent, and a couple of other cam mnfrs, to see what they've come up with.
And I'l have to set it up on first on a rod and pistonless upper engine case so that I can see into the barrel and check clearance between valves during the rotation of the engine.
I reckon that's a week's work, and I'll try to get it finished in time to get Dyno work done on Friday with the MWR filter.
Best get started, then.
