Had a good look through the archive, not found anyone mentioning this.
Adjusting the mixture air screw is damn near impossible as the carb bottoms (the bit with the pilot screw) are tight up against the cylinders. There is a scein of cables and hoses in there, plus the expansion bottle.
It is simple, the water bottle can be slid out, with a bit of origami, take the bottles breather pipe out of the bunch hanging down by the side of the front cylinder. The water bottle is secured with an 8mm head bolt under the R/H frame spar. With this removed the bottle can be wiggled out leaving you with clear and easy access to the airscrews. Adjustment when the engine is warm can have a remarkable effect on the tickover / low rpm performance.
Air mixture screw made easy.
Re: Air mixture screw made easy.
Search for mixture screw tool, Benny Hedges beat you to it.
His works, too!
His works, too!
Cant find a reference to it, but I'm guessing its a springy screwdriver idea? They are OK in their way, but being able to approach the airscrew diectly and feel your adjustment will always do it for me,
I agree. If you are having a screw you should be able to feel it.jdugen wrote:Cant find a reference to it, but I'm guessing its a springy screwdriver idea? They are OK in their way, but being able to approach the airscrew diectly and feel your adjustment will always do it for me,
- benny hedges
no springyness at all. turn the end 1/4 turn & the driver end moves 1/4 turn - dead easy to make.jdugen wrote:Cant find a reference to it, but I'm guessing its a springy screwdriver idea? They are OK in their way, but being able to approach the airscrew diectly and feel your adjustment will always do it for me,
the one with the yellow crimps was easiest to make & works best.
Nope. Getting a screwdriver right on the airscrew, turning it in till it grounds and then adjusting it in small increments is the only, truly accurate way. I'm done in about five minutes including removing, replacing the overflow bottle. BTW, that damn thing is being relocated right out of the way, stupid place to put it, who actually designed this thing? (Saw somewhere that the American branch of Honda had a big part in producing this design.... Now that WOULD figure).
