the best firestorm front end i've ever seen.
Re: the best firestorm front end i've ever seen.
Wow. That's very subtle but beautiful.
Never argue with idiots. They drag you down to their level then beat you with experience!
Agreed. Only improvement I'd make is yellow!
KriegerCCTs,HEL oil lines,+4 advancer,+1/-1 sprockets,6mm spacer,CBR1k Sidestand,'07 R1 R/R,HyperPro springs F&R,Pipe Werx SL Carbons,Oxford sports hot grips,Mori style belly
Immediate plans:Clean it!
the fella said he had a custom screen made, you can buy a sharkskinz top fairing which loses the small light, but the screens the bugger, and those mirrors look great. as i said the best front end i've seen.
i just gave some mirrors away same as them trust me there gash
as for the rest its so subtle i cant see the mods but im fightering mine so cant compair
bikes bought dead or alive crash damged , none runners , abandond projects
You aint seen mine then Marty lol. That guy must have though coz he's copyed me by putting mesh in the air ducts.
Theres A Hare in The Turnips.
On second viewing,Where's the parking light and separate panel?
hahaha its very clever what this guy has done, it looks pretty normal until you take a closer look, i'm thinking of doing mesh in the air intakes and maybe putting indicators in there aswell. i would like to know where he got his screen from tho? the other idea i was tinkering with would be to fill in the park light and either side of it to make a continous smooth line at the bottom of the screen, which would mean you could keep the original screen. get some pictures up of your bike simo....
Sharkskinz GRP one-piece upper fairing from USA
http://sharkskinz.com/shopexd.asp?id=1127
Though aussie shayne said he made the stock fairing one-piece presumably from fastening it all together and filling the joins, before respraying.
http://www.superhawkforum.com/forums/me ... post260320
http://ozfirestorm.proboards.com/index. ... hread=1913
simo wrote:On second viewing,Where's the parking light and separate panel?
- benny hedges
carefull with the cooling on that one m8 - them holes do have a purposebigspanishmarty wrote:i'm thinking of doing mesh in the air intakes and maybe putting indicators in there aswell.....
i noticed tattoo has put indi's in the air duct holes and it has effected his temps, i will be looking into maybe putting an air sccop underneath the headlight to provide extra cooling for the engine, cheers for the heads up tho buddy.....
Can't do that very well because it would mask the oil cooler....bigspanishmarty wrote:i noticed tattoo has put indi's in the air duct holes and it has effected his temps, i will be looking into maybe putting an air sccop underneath the headlight to provide extra cooling for the engine, cheers for the heads up tho buddy.....
So consider moving the oil cooler down to just above the oil filter, then you could fit a scoop to duct air into the area just in front of the air intake snorkel, and seal up the triangular area behind the headstock to give you some ram air...
But you might just as well fit a scoop with a sideways exit, aiming the air onto the rads....
Nothing's ever easy, is it?
marty......the temp gauge was just under half way even in this cold weather so i took them out
i have however picked up 4 broken fairing panels today to experiment with...i'm thinking of doubling the airducts up so the inners stay open for air and the outers will have indi's inside....
keep me posted buddy, i'm going to try and use the ducati 999 headlight on my storm, so i might try the same style of indis as you have done but tinker with the fairing to add some new air vents, it will give me something to do over winter, if you wanna sell the punto indis let me know and i'll have them off you, only if your not gonna use them tho mate.......tattoo wrote:marty......the temp gauge was just under half way even in this cold weather so i took them out
if memory serves me correct its actually from Australia this bike on an oz firestorm forum, might have a link to it / the guy some wherebigspanishmarty wrote:from the superhawk forum.
I asked him about the indicators trying to get help as I wanted his mirrors but he wasn't very forthcoming
Check that link out lots of pics and can ask the guy stuff if you want info.
