I got my pyramid bellypan back from the painter today, and a beautiful job he has made of it too. He also sprayed a bar across a clear headlight cover, just to change the look of the front end slightly.
The pictures don't do the finish justice as they were taken with flash -
I will stick the headlight cover on tomorrow and post some pics up, as long as it isn't pi**ing down. The bellypan won't be going on for a while until I finish the winter mods.
I is a happy bunny.
Carpe diem, quam minimum credula postero F3, 954 USD front, K Tech springs, Braced swinger, Ohlins shock, Six spoke Mockesini wheels, Harris rearsets, QaT, Flywheel diet!, A&L stacks, stick coils, K&N, FP Ti jets, Mori pipe's [colour]
The paint, PB215C Candy Tahitian Blue, cost £100, £10 for a glassfibre repair of a crack, which was on it when purchased used from here, £30 prep (quite involved as there was some damage to the Gel coat along the bottom) and £30 to spray it up.
I thought it was a fair price for a top job.
looks good buddy, i look forward to seeing them on the bike. if you need anything spraying next year let me know because i've just bought a litre of pb215c and i will have loads left over after spraying, but i had to buy a base silver aswell, not bloody cheap mate.....
But worth every penny mate. You wouldn't want to cut corners and end up with something yellow!
Was the headlight cover along the lines of what you were thinking of?
make sure you fit some heat reflective stuff inside where the front header goes otherwise that lovely paint will bubble off
cheapest option is go a scrapyard & cut some bonnet insulation off a car then glue it inside the belly before it goes on.
Just ordered some heat mat from the purveyor of all things, E Bay, and will keep in mind the adhesive.
As to the headlight cover it may well be a case of form over function, but nothing ventured nothing gained and all that. It is held on by velcro so can be removed easily if needs be.
Kev L wrote:But worth every penny mate. You wouldn't want to cut corners and end up with something yellow!
i'm going a bit more extreme on the front end matey.
1 x headlight surround original.
1 x clear headlight protector.
2x ducati 999 headlights.
and a bit of imagination/swearing/luck and i'll come up with something abit different..........
i'm getting some heat resistant matting to go on my fairing lowers, theres a company that sell it on ebay, looks like pretty good stuff.
i've got some spare honda wing decals in silver if you want them for your lowers mate?
Ok, as promised I fitted Dame Edna's glasses to the front of the bike today. I quite like the look, which just disguises the look a little.
For a cost of £17 for the light protector and the cost of paint (done at the same time as the belly pan so I can't give a cost), I think it's a nice cheap little mod.
Haven't ridden the bike yet, so I don't know the impact on the lights and beam distortion-
