Project "SHREK"
karenvtr
Project "SHREK"
Post by karenvtr »
Hi everyone .. It was suggested that I should move my winter project thread into this section so here it is :)
This was Shrek when it arrived.
It didnt look to bad at a glance but a closer look revealed the years of neglect :(
Hubby assured me it wasn't as bad as it looked :? It started ok from a lazy battery but it was clear the front pipes had seen better days,the front wheel was porous and the frame and metal parts were in need of attention !
The front pipes took some removing, one of the manifold studs snapped but we eventually got it out by welding a nut onto the remainder of the stud, I recall quite alot of swearing going on at that point :lol: The frame has been rubbed down, Kurust treated and repainted ( its getting more paint soon) Wheels were blasted and painted white and an oil and filter change while we were there.
So that's about it for now as were waiting for a few bits n bobs to arrive but I think its coming on :D I will keep you all updated :thumbup:
Re: Project "SHREK"
its amazing what a bit of elbow grease and some paint can do, its looking very good karen, keep it up.......... :thumbup:
Re: Project "SHREK"
That second shot looks like part of a North Sea oil rig!! It should keep you busy through the next few weeks.
Good luck.
Re: Project "SHREK"
It sure looked rough under the surface, but looks like your hubby was right, it scrubs up well. :thumbup:
marravtr
Re: Project "SHREK"
Post by marravtr »
looking good! been looking for a cheap gpz 900r for a while to do myself :wink:
vtwin goody
Re: Project "SHREK"
Post by vtwin goody »
:clap: :thumbup:
BigVeeGrin
Re: Project "SHREK"
Post by BigVeeGrin »
marravtr wrote:looking good! been looking for a cheap gpz 900r for a while to do myself :wink:
fab bike and engine - great project :D
karenvtr
Re: Project "SHREK"
Post by karenvtr »
Thanks everyone its coming along nicely now ..sure was rough when we started ...brakes need a good look at then time for a test ride :D
karenvtr
Re: Project "SHREK"
Post by karenvtr »
Brakes sorted test ride complete :) ...lol ...then we started messing around with it as it was a bit lumpy and now it wont start lol so more tinkering needed :D
Re: Project "SHREK"
I had this with a zxr6 I rescued from a long stand on its own in a cold shed.
Strip the carbs once more, clean thoroughly, and fit an in-line fuel filter, to stop bits from the tank clogging jets up.
If the bits are softer than rust, it's the insides of fuel lines or maybe a carb/fuel tap gasket disintegrating.
karenvtr
Re: Project "SHREK"
Post by karenvtr »
Its alive again :D :clap:
Turns out it was just a weak battery after all that, Seemed to kick it round ok but just didnt have enough to start it :?:
Was funny watching Chris cringe as one of our neighbours rode it side saddle bouncing on and off it down our road last night untill it started :thumbup: New battery fitted and now it cracks first time :cool2
Almost there with it now,just had new plugs and air filter then fresh fuel but im still not happy with the finish on the engine laquor think were going to have to do that again !! The belly pan is being fitted as I type then its time for a good wash n polish :D
Now to decide what to do with it once its finished :roll:
Re: Project "SHREK"
Keep up the good work, another bike saved from the breakers, well done :thumbup:
ChrisC
Re: Project "SHREK"
Post by ChrisC »
looks very nice indeed.
ride safe :thumbup: chrisc
