running rough
benny hedges
Re: running rough
Post by benny hedges »
thumperslaw wrote:
190 jets and it does not pop and bang so much when you let the throttle off.
180 jets and its like a fire work display
you have air leaks.
check the carb rubbers and check the headers
thumperslaw
Re: running rough
Post by thumperslaw »
If I had then a leak test would of showed that I would of thought.
200psi in the cylinder
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
benny hedges
Re: running rough
thumperslaw wrote:If I had then a leak test would of showed that I would of thought.
not really.... it would only show that the valves & rings are sealing well... lots of popping and rough running is often caused by air / vacuum leaks between the carb & the inlet, which would be on the other side of the inlet valves... and also lots of popping on over-run is often caused by leaking headers, which again, is on the other side of the exhaust valves.
might be something else, but is definately something to rule out. :beer:
thumperslaw
Re: running rough
Will try that as you said its worth checking to see.
K100 "flying brick"
benny hedges
Re: running rough
defo mate, especially the rubbers... they do harden off over time and the clips get weak.
you may think theyre good and tight but if theres no flex in the rubber they could well be letting air in.
as a result it weakens the mix by drawing air in after the carb, and also loses vacuum which affects the rate of rise on the slides.
when you refit the rubbers, its worth smearing a bit of grease around the mouths as it helps them seal. and try using an 8mm socket on the clips instead of a x head screwy...
thumperslaw
Re: running rough
At the moment any thing is worth a try.
I know the headers are tight and now leaks from them. I used new exhaust studs and gaskets from Honda and checked that all. My storm had been sitting for awhile before I swapped the motor over
K100 "flying brick"
Re: running rough
This seems more likely to be a vac pipe/carb balancer on the front pot being open to atmosphere.
Question:
Although the bike pops and bangs, in second gear, will it rev up to 8000 plus easily?
If it does, the timing's ok.
If it gets to about 6500 and won't rev any more, the timing is out 180 degrees.
But having ridden bikes with the timing out 180 degrees, there's no appreciable popping and banging, as I recall, it just feels as though someone has put a sock in the air intakes, and it simply can't get air in quick enough.
Why don't you ask one of the local boys to have a look at it for you?
Chances are that it's an easy fix....
thumperslaw
Re: running rough
Revs up to the red line apart from in 6th gear just will not get there.
Bypassed the side stand switch tonight just to cross off list and looked at the wiring again.
Going to keep on trying looking and also got the vtr guy roger coming over work shop I think
K100 "flying brick"
Re: running rough
thumperslaw wrote:Revs up to the red line apart from in 6th gear just will not get k
Ok, so it's not the cam timing, but it has to be something else that was disturbed with the new engine.
thumperslaw
Re: running rough
Story goes
I got this engine from a guy who lives in oxfordshire who used to drag race them and his son also. The motor I got had done to drag meets then it was stripped and rebuilt again
K100 "flying brick"
