Frozen starts not good
Post by Image »
On frozen mornings my battery is tired and doesn't start the bike. Tried a brand new battery, still same. Any ideas?
Re: Frozen starts not good
You could try checking the starter motor lead.
First, though, check battery terminals.
I've known the lead to start to corrode inside the insulation, so just to check try adding a length of cooker flex in addition to the starter lead, bolted firmly both ends.
If it starts easily, that's the problem.
Otherwise, but less likely, starter motor brushes.
Post by Image »
Thanks. I'll check that. Already checked battery terminals are tight.
Steve6088
Post by Steve6088 »
|ve been having the same problem with mine when it has been left out overnight in this very cold weather. Starts fine again now it is slightly warmer though :D
Fireman on a Storm
Post by Fireman on a Storm »
I had the same problem on both of mine even when left in the garage. An optimate charger solved the problem. Once started in the morning it would be fine all day.
A 1000cc v twin with lots of compression and cold oil does need a healthy battery!
bazza696
Post by bazza696 »
I have found the best method is to cover it with an electric blanket and a duvet over that. :D
bazza696 wrote:I have found the best method is to cover it with an electric blanket and a duvet over that. :D
and then get in the car and go to work! :D
seb421
Post by seb421 »
Strange that so many have problems with the cold, mine gets fired up at 3am when its very very cold in an open warehouse and it goes on the button first press
Has had a new type Honda R/R about 6 month old, and a new YUSA batt about 2 year ago.
No corrosion tho, and I use Vaseline under the rubber boot of the starter motor to keep the sh1t from corroding in there
20 mile run each way to work on the motorway
Steve6088
Post by Steve6088 »
CO
seb421 wrote:Strange that so many have problems with the cold, mine gets fired up at 3am when its very very cold in an open warehouse and it goes on the button first press
Could just be that the 20mile run is giving you battery a decent charge. I'm only riding a few miles to the train station as it is too cold to ride all the way. I don't think this helps.
Try stick coils and new plugs
Mine used to be a git to start but now it's tug tug tug BANG vrrrruym
Sorry officer
The voices made me do it
Post by Image »
Yeah, it starts fine the rest of the time. Like Steve6088 it's when it's left out overnight on frosty nights. I wonder if it's because it's a twin. A 4 cylinder 1000cc bike only has to fire up one 250cc bore to set things off but storms have to ignite a 500cc bore. That's a big piston.
Fireman, tell me more about optimate chargers. What are they? How much? Where from? What difference do they make?
Incidentally, one day last week here it was minus 4 all day and storm wouldn't start after a days work. Embarrasing. All other times it's done that to me though have been early dark frosty mornings. I've had to invest in a battery booster. Not an ideal solution.
Fireman on a Storm
Image wrote:Fireman, tell me more about optimate chargers. What are they? How much? Where from? What difference do they make?
Optimate is a brand name. Basically it's battery charger/battery mantenace. You wire the supplied lead direct to your battery, this has a plug on it that you cable tie in an accesable position. When you park the bike up plug the charger into the cable tied plug and switch it on. The chager basically monitors your battery and charges it if it loses charge while parked up.
Look here
http://www.optimate.co.uk/optimate%203+.htm
I can't remeber the make of the one that I have got but it was only about £25.
Once I started using mine it didn't matter how cold it was or how long the bike had been park up it statrted on the button every time, first time. Even after a 2 month lay up because I was baby sitting a 1200 bandit for a mate and using that every day it still started first time.
Post by Image »
Good kit but the problem I have with the optimate charger is that it involves removing the seat and disconecting the optimate charger each morning which is pretty much the same as what I'm doing now to use a battery booster. Call me fussy but I expect to just jump on my bike and go.
No, they come with a waterproof socket that you wire in (with an in-line fuse, 7.5 watt, also supplied)
So you then just undo a connector and ride.
This was a handy inexpensive mod for mounting a plug & play Optimate connector - http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=11632
