lloydiecbr wrote:bigspanishmarty wrote:everything stays the same, you just change the velocity stack/trumpets to whatever you want, i would recomend a more free flowing air filter.....k&n or bmc or pipercross...... but then you would probably need some rejetting and lighter more free flowing exhaust cans. where will it all end
it don't end I'm already thinking about. +1 pistons and porting&polishing
Been there, done that, back to playing with airboxes and filters.
Next games are about crankcase porting, possibly pressure reduction in the cases, but definitely exhaust port rerouting.
By which I mean that the actual exhaust port needs moving sideways; as standard they are offset to one side, and only one of the two valves is directly in line with the port, but the other is hidden.
Simply moving the port to a more central position should liberate some power.That's what the SP1 and 2 have, and they develop a fair bit more power with much the same engine architecture.
But it's a lot of work......
