Hello
Does anyone know what the air cut off valves do ? What circuit are they on?
Carbs
Re: Carbs
I shall answer my own question in case any one else wants to Know .When you shut the throttle a high vacuum is created in the inlet.This is used to operate a valve that shuts off the air to the pilot jet circuit causing a richer mixture to prevent banging and popping on the over run.
Re: Carbs
yep, ill second that mate!tony.mon wrote:Name and shame that guilty valve!
I LIKE popping and banging on the overrun.......
Re: Carbs
It doesn't just stop noise it also stops the exhaust valves from burning.
- chris vtr virgin
Re: Carbs
You canny beat the popping and banging the louder the better.
Some twins have all the fun !!!!
