Intermittent clock backlights
richey_t
Post by richey_t »
Hi,
For some reason the tachometer and oil meter backlights keep going on and on (usually over a bump)... any ideas if there is something easily accessible to check, maybe a connection or something?
Thanks
Richey
Re: Intermittent clock backlights
Greetings
3 bolts hold the clocks on - take a look at the back of the unit for loose/corroded connectors and if necessary replace bulbs.
Downloadable PDF Honda Service manual is available in the workshop knowledgebase section along with stickied topics to keep you occupied for a while - esp CCT and R/R preventive upgrades.
And post some pics of your new storm beasty!
richey_t
Post by richey_t »
Fantastic! Thanks for the info :) I will post some piccies very soon!
