Spitting in the air box.
StormingHonda
Post by StormingHonda »
When you start the bike up, you get a spitting in the air box, apparently there is a K&N air filter fitted, the seller said this is why, knowing better I feel its more the fact that the carbs probably have been rejeted and the fact the owner has put the standered cans back on is making it spit back.
Any thoughts?.
benny hedges
Re: Spitting in the air box.
Post by benny hedges »
Turn the idle to about 1200 and it more or less goes away
Carb farts are quite normal storm behaviour
Balancing carbs also helps.
bazza696
Post by bazza696 »
I will bring the carb balancer with me on the maintenance day.
does yours have the vac pipe take offs fitted?
Flatline
Post by Flatline »
I fart a lot if I eat a lot of carbs.........is that what you mean?
If so, stop eating carbs :lol: :lol: :lol:
StormingHonda
bazza696 wrote:I will bring the carb balancer with me on the maintenance day.
Not entirely sure, I'll take a look the weekend.
It'll have the rear one; it the front one you need to check.
If you look below and to the right of the front carb rubber, where it meets the back of the head, there will either be a rubber pipe of about 10mm diameter coming off, or there will be a cap head screw still in place.
StormingHonda
tony.mon wrote:It'll have the rear one; it the front one you need to check.
I'll check it out in the morning
balls
Post by balls »
i don't normally spit in the air box cause you have to take the lid off , sorry I will get my coat :eek2
