Which Reg/Rec
Which Reg/Rec
Am about to buy a replacement RR, but have 2 options. Original Honda, updated version, or Tourmax. I'm a bit of a sucker for original parts, but the tourmax is a bit cheaper. Anyone using an aftermarket, and any issues ??
Re: Which Reg/Rec
No takers....Think I'll order the original Honda part then.
Re: Which Reg/Rec
Lee, I may well be tempting fate here but my 2003 Storm with the finned RR hasn't given me any problems. I would hope you would be OK with the later one fella. It has the big advantage of being plug & play as well. Good luck.
Re: Which Reg/Rec
Most use Yamaha R1, look in the Workshop Knowlege section. If the ones you're talking about are the big alloy finned type they should be OK.
Theres A Hare in The Turnips.
Re: Which Reg/Rec
TBH I never had a problem with the old style one on my previous storm, and I had it 4 years/32000 miles. However, I do know theyre a weak point, as my mates went wonky halfway through Belgium one year and don't fancy it myself. Cheers FellaKev L wrote:Lee, I may well be tempting fate here but my 2003 Storm with the finned RR hasn't given me any problems. I would hope you would be OK with the later one fella. It has the big advantage of being plug & play as well. Good luck.
