How long is a Firestorm steering stem?
ive found one on a set of billet yolks thats 220mm long, fancy my chances it'll fit?
Re: How long is a Firestorm steering stem?
Chances are that you could grind off the Storm stem and remove the stem, then fit it onto the new one.
But it might fit anyway.
You can get bearings of almost every possible diameter, so that shouldn't be a problem.
And if it is, cut the steering stem off the frame and have one from whatever the yokes are from welded on.
Everything's possible if you try.
