Well, I already had the spare crankcases, from a bike I broke for spares last year. That engine was low mileage, but was jumping out of second, and had cct failure/bent valves on the front pot so I've used the crank that goes with the cases, as the mains and big ends are still good, but my own gearbox and selectors.
Costs so far are less than £200 for the usuals, head gaskets, 2 sets of rings, new valve seals, copper exhaust compressible O rings, big end bolts, a new clutch centre nut and a clutch pushrod seal.
Oh, and oil, coolant and a filter, obviously.
The welding on the crankcase boss was a tenner for cash, and the local rebore place deglazed the bores for a tenner cash, too.
So far this is my seventh solid day doing it, it looks to be finished tomorrow, unless anything else unexpected gets remembered in the night!
Then just the front end rebuild to go, refresh fork oil and fit new taper rollers, current ones are just starting to feel slightly notchy....Maybe the weekend after the workshop day.
Or I might just ride it a bit
