If you back the damper right off you should hardly feel it, then add a click every few miles till you get the best compromise between slow corners and high speed stability
Vtrkidda
Post by Vtrkidda »
How do i adjust it please it was used and has no instructions with it ,there is a adjustable thing on the bar bit then a inner sort of adjustment on the shock bit :confused god that ws hard work :lol:
Loud pipes save lives!
playerone
Post by playerone »
Vtrkidda wrote: ,next new rubber chain
A metal one will last longer :thumbup: :lol: :lol: :lol:
Vtrkidda
Post by Vtrkidda »
I knew some one would say that just.knew it :clap:
Vtrkidda wrote:How do i adjust it please it was used and has no instructions with it ,there is a adjustable thing on the bar bit then a inner sort of adjustment on the shock bit :confused god that ws hard work :lol:
The little knurled knob or the rod right hand end as fitted. Clock wise is more damping, CCw is less
Vtrkidda
Post by Vtrkidda »
Thanks mate ill give it a go next time im out :thumbup: :thumbup: cheers :biggrin
marravtr
Post by marravtr »
phil ive got mine set 4 clicks in, feels very good on the twistys :thumbup:
Vtrkidda
Post by Vtrkidda »
:shh: no names on the forum please :shh: :lol: ill try it mate 4 clicks :thumbup:
Vtrkidda wrote:I knew some one would say that just.knew it :clap:
:lol: :lol: :lol: :lol: This forum has me in stitches, so mutch better than TV :lol: :lol: :lol: :lol:
boz
Post by boz »
bigspanishmarty wrote:sounds like you won't have a problem there bozzer.........you've caught the vtr modding illness haven't you :lol: :lol: :lol:
Damn right, gonna make this bike truly mine and hopefully unique. Searching for carbon fibre look fairing lower and rear hugger as I type. Carbon fibre is the new black! :clap: :clap:
CBR900rr Fireblade
marravtr
Post by marravtr »
Vtrkidda wrote::shh: no names on the forum please :shh: :lol: ill try it mate 4 clicks :thumbup:
ooops sorry kidda, stealth mode from now on :biggrin
tankslappa
Post by tankslappa »
Well tonight's post should have been "Bled all the hydraulics, brakes are now super sharp"
Instead...
Drained front brakes, completely failed to bleed new fluid through, so now have no front brakes at all. Bleed pipe came off so fresh DOT5 spilt all over the calliper and front wheel.
Rapidly rinsed off with soapy water.
So now I have a bike with no front brakes sitting in a puddle in the garage.
I f*ckin' hate bleeding brakes.
I think I'm gonna take the callipers off, it's like trying to do keyhole surgery trying to lock and unlock that nipple between the brake pipe and the fork leg.
marravtr
Post by marravtr »
tankslappa wrote:Well tonight's post should have been "Bled all the hydraulics, brakes are now super sharp"
Instead...
give over its a piece o piss, bring it up ere and i'll do it for you! mind it'll be a dodgy ride wi no front brakes :biggrin
This might help http://www.ebay.co.uk/itm/Speed-bleed-v ... 53df9ad33c or you could get a mate round to to make it easy. Get him to do it. :lol: Brake fluid everywhere :roll: :eek2 :(
tankslappa
marravtr wrote:
tankslappa wrote:I f*ckin' hate bleeding brakes.
I know, it should be, but so far the only step which has actually gone right is the bleed nipple weren't jammed!
After that it was down hill all the way (with no brakes!).
cybercarl wrote:This might help http://www.ebay.co.uk/itm/Speed-bleed-v ... 53df9ad33c or you could get a mate round to to make it easy. Get him to do it. :lol: Brake fluid everywhere :roll: :eek2 :(
They certainly would help! I've been trying to use some EZ-Bleed pipe things, but I haven't used them for a while, and they were for the car. I don't think the bike brake has enough pressure to blow past the ball thingy, so nothing happens!.
Will the bike gravity bleed? Maybe I should try that. My car's rear brakes did that... Took a couple of hours, but it was most relaxing.
