Cant remember the technical word for it, but where's the easiest place to pick some up and is it the same dia as used in brake bleeding. New lines on the way and want to check my carbs to.
Ta Folks.
Carb Balance Clear Tube Thingy Stuff
Re: Carb Balance Clear Tube Thingy Stuff
Vacuum Tube !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Here you go http://www.carbtune.com/ very fast service as well.
I bought tube and brass adapters at the same time. Then made a permanent connection running to under my seat, as you saw the other day
iirc it was the 5mm adapters but check with the workshop knowledgebase for carb sync first.
