New Chain
darrenmartin
New Chain
Post by darrenmartin »
Hi guys iv just bought a new chain and Chain splitter but to be honest i aint got a clue how to use it :oops: any help would be welcomed. Iv checked the chain thats on the bike and because theres no split link i asume i have to grind the head's off of one of the links.. is that correct? :think: heres the Chain and splitter Image Image and the splitter...Image Image...again soz for being a bit thick :roll:
Last edited by darrenmartin on Thu Jun 21, 2012 11:53 am, edited 2 times in total.
Like Riding Thunder and Lightning
Re: New Chain
Grind the heads off two pins on the same figure-of-eight shaped link, then punch them out.
Re: New Chain
or take the left footpeg hanger off and rear wheel off and simply drop the chain off and install new endless (riveted) chain.
Re: New Chain
The picture looks like the Motrax one I have. Have a good read through the instruction sheet and it tells you which heads to use for which purpose.
darrenmartin
Re: New Chain
But it will be the Endless type link i use to connect the new chain wont it (not the open end link) :?:
Re: New Chain
Yes, it's the endless link you need, don't use a link with an open end held in place with a clip.
darrenmartin
Re: New Chain
:thumbup: thanks Toni
Re: New Chain
1st off it's never a good idea to just change either the chain or the sprockets on their own. These should be changed at the same time as each other, hence the reason you get a lot of chain and sprocket kits.
The reason behind this is that the chain and sprockets wear in together. If you put a new chain on old sprockets that chain will wear down a lot faster and visa versa.
To remove the old chain, the quickest and easiest way is to angle grind the old one off. It's a good idea to do this with the rear wheel removed as not to damage it or the tyre. And is easy to cut where the chain hangs below the swingarm. The new chain will be already split with a link to be used to join the chain back up. This is where the chain splitter/riveter comes into play. IMO all the cheaper type (£30-£40) mark are not that good and the pins on the tool have a tendency to bend if overtightened.
Wrap the chain round the sprockets and place the split link through to join it up. Don't forget to put the O rings in place if you have any, and use plenty of the grease normally supplied. You will then have to put the O rings and plate over the other side. You then place the chain/split link in the chain tool and squeeze the pins so the heads of the pins flatten out/dome over like the head of a rivet, to stop the plate falling off while riding down the road :eek2 This is where a lot of the cheaper tools fail. You need to get the pin on the tool square on and tighten it up so the end of the pins on the split link roll over. It needs a lot of pressure but not so much that the link does not move freely. I have found that the pins on the chain tool have a tendency to slip off as you tighten up, and the amount of pressure needed can bend the pins on the cheaper tools. So take it easy and go slowly but surly.
The last time I done a chain I managed to get the link pins bent but then the pin in the tool bent. Luckily enough it was OK for me to ride very carefully down the road to a motorcycle garage, where they very kindly (from a safety point of view) Finished off the last bit for me while I waited.
Hope that give you some insight :thumbup:
Re: New Chain
as Wicky points out, you can fit and remove an endless chain on the firestorm if you remove the swing arm nut and the L/H footrest. So I took my new chain and link to my local bike shop and had them rivvit the link together on the bench [with their professional kit], then took it home and fitted it....they did it for free :thumbup:
if you have added a brace to your swingarm this wont work :(
Re: New Chain
Here you go Darren http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=16500 some nice pics here to illustrate things. :thumbup:
darrenmartin
Re: New Chain
:thumbup: thanks for the info guys thats helped loads oh and i should of said in my origional post i have bought new front (with 1 tooth dropped) and rear sprockets to go on with the new chain......soz :thumbup:
