Front fork internals: Now sorted
Flatline
Post by Flatline »
I need to remove the silver part at the bottom
It is supposed to come off easily, but it doesn't
Any suggestions on how to remove it?
Sensible is good :thumbup:
Not sensible is funny :lol: :lol: :lol:
You choose :problem: :problem: :problem:
Re: Front fork internals: How to remove this part??
I don't know how for sure as I have not investigated the internals of my forks yet. But from that picture it looks like the bolt in the end holds that on. So is it supposed to just slide off :confused It would be a tight fit!
How about an adjustable spanner, not closed to the point of clamping around. But just above the silver thing there is a lip, so put the spanner above that sitting on the lip and give the spanner a tap with a hammer to knock the silver thing off. You will need a third hand to hold your rod (I think I will rephrase that :lol: ) Get someone to hold the rest of it as you will need two hands. One to hold the spanner and one for the hammer. :thumbup:
And check to see if there is a circlip around the inside of that lip or it might have a metal ring like on the top of the forks.
Flatline
Post by Flatline »
Thanks for reply
The bolt on the bottom is not part of it
There is an allen bolt that goes up the fork leg to hold it down
I am reliably informed that it should drop off :eek2
Need I rephrase that? :lol: :lol:
It's made of alloy so very soft
Slidehammer :lol: :lol:
What you need is a fork seal tool/driver, or something round and hollow to slide over the other end of the tube down onto the lip, and knock it off. Or do as I suggested above. You cold always wrap it in a rag to protect it somewhat and be gentle. Well gentle to start with until you get pissed off with it. :lol: :lol:
gafr
Post by gafr »
they should readily pull off after removing the bolt, but be very careful as they break quite easy, dont try to use anything with teeth ie pliers , as these will mark them and bugger em up. afraid its a case of pulling the offending item.try wrapping a rag around your hand and then twisting and pulling at the same time.
tasum
Post by tasum »
if it should just pull off you could try one of those rubber wrenches with the strap like a boa constrictor to put around it and then pull it off.
something like this
http://www.amazon.co.uk/Miscellaneous-B ... B0001J0456
we use one for opening jar lids :)
hope this helps :D
slow is smooth, smooth is fast
I like the boa constrictor idea. Good thinking tasum. :clap: :clap:
tasum
Post by tasum »
cybercarl wrote:I like the boa constrictor idea. Good thinking tasum. :clap: :clap:
my one useful thought for the week, just lucky it landed here :D :D :D
still sorting out my baffles :(
Flatline
Post by Flatline »
Tasum, bring it Friday m8
tasum
Post by tasum »
Flatline wrote:we use one for opening jar lids
will do, but do you prefer jam or peanut butter?
edds11
Re: Front fork internals: Now sorted
Post by edds11 »
filter wrench....the ones with a kanvas strap
Flatline
Post by Flatline »
Had the fork internal with me in the van just in case I came across someone to help, and I did :thumbup:
He has a new piece of kit that heats the end up without flame
So, job done
Flatline wrote:Had the fork internal with me in the van just in case I came across someone to help, and I did :thumbup:
So, job done
That's good news :thumbup: So was it just a case of a tight fit (ooh err misus :wink: ) :?:
Flatline
Post by Flatline »
Yep
Flatline wrote:Yep
