worped discs
worped discs
what do they feel like ? i have a jerky pull up when going slow, cluch in to a stop. hard to feel when brakeing hard at speed !
- Fireman on a Storm
Warped disc
Mine's been like that for ages (pulsing brake lever)
Became more noticeable after sintered pads and braided hoses. Can't be bothered to pay £340 for two new discs plus pads! I don't use the fronts much at slow speed anyway so it isn't too noticeable at speed
Re: Warped disc
Yep, warped brake disc. Lift the front wheel off the floor and spin it, you can often see which disc is warped by looking at the gap between disc and fork leg.logan7 wrote:what do they feel like ? i have a jerky pull up when going slow, cluch in to a stop. hard to feel when brakeing hard at speed !
Lots of examples on ebay for much less than £340. Honda used the same discs on loads of bikes, VTR, Fireblade, CBR6, VFR...Stratman wrote:Mine's been like that for ages (pulsing brake lever)
- essexbloke
Might be worth getting in touch with Busters as they had some discs going very cheap not long back - here's the link:
http://www.busters-accessories.co.uk/pr ... d=249&pg=2
Ohlins shock, Goodridge lines, 6-pot calipers, carbon fibre hugger.....and all at someone else's expense!!
- firestorm_al
- Site Admin
- Contact:
just had my bike into the dealer about the discs. mec had a test ride yup they are worped. ok new discs under warranty. only had the bike 4weeks . just got home phone rings sorry discs not covered under warranty.
how can you sell a bike with worped discs said i . mecs never said owt when it was checked out in the workshop she says, and they are good lads. bullshit i smell. fit them in good faith i say. they are going to get back to me. will keep you posted.
- tony.wilde1
discs
if the discs were that bad and it came with a years m o t then they passed it like that!!which is well dodgy...they should replace them because they wont want a call to the m o t will they
good luck logan
they are now saying 1 disc is bent i must have dropped the bike!
I have not dropped it and would go on a liedetector it say so. the brake lever is a bit bent it was like that from the start they are saying it was not like that when it left the workshop. its my word against them but they can come up with 3 or 4 mecs and 2 or 3 salesmen.
