Mini indicators
G-Pro29
Mini indicators
Post by G-Pro29 »
Hi I've bought some mini arrow style indicators and the spacers I've got are too small for the holes on the fairing any ideas how to fit them ?
Cheers Gav
VR46.......SUPERSIC 58
Re: Mini indicators
You can get larger spacers, or fit large cats eye types, or the large teardrop ones.
The other option is to use tiny ones with long stems.
Have a look on the "pimp your ride" section for some ideas, and how they look.
G-Pro29
Re: Mini indicators
Post by G-Pro29 »
Cheers tony I will do just that
stu72
Re: Mini indicators
Post by stu72 »
Gav,
I have got some Motrax LED indicators on mine. Motrax do Indy Spacers. Unfortunately they do not do ones for the Firestorm, only SP1 or SP2. The best fit I have found are the Kawasaki ones. They are a tiny bit small but do just about fit ok.
Stu. :)
G-Pro29
Re: Mini indicators
Post by G-Pro29 »
stu72 wrote:Gav,
Stu. :)
Which Kawasaki ones did you use stu, thanks for the advice pal.
stu72
Re: Mini indicators
Post by stu72 »
Gav,
I used Motrax Indy spacers reference ISK1.
The Motrax LED indicators were on the bike when I got it. On the right side of the bike there is a shaped rubber grommet that runs around the edge of the hole in the fairing. The spacer fits nicely on this side. On the left hand side the grommet is missing and so the hole in the fairing is a little bigger all the way round. If you have the rubber grommets they should fit fine. If not, they should still be ok but not quite as neat as the spacers are only slightly wide than the hole and about 2mm shorter than the hole.
Stu.
stu72
Re: Mini indicators
Post by stu72 »
Forgot to say that you can get them for about £5.00 including postage on ebay.
Stu.
G-Pro29
Re: Mini indicators
Post by G-Pro29 »
Cheers stu
That's a big help pal thanks.
Gav
Mav617
Re: Mini indicators
Post by Mav617 »
Anyone know of any indicator spacers to fit the Storm? Front. (old topic resurrected)
